Can you reverse front wheels on mf65?
Rkh
Can you reverse wheels on front end of my mf65? With wheel reversed,it lines up with rear tires, center to center. It was also rubbing on right side of steering. The first picture is normal installation, second picture is with wheel reversed.
If you use a loader, the added force on the spindle can increase bearing wear, but if not (and your bearings are good (both in the hub, and the spindle) it will be OK. Expect a little harder steering. Jim
