tomstractorsandtoys
Your post made me want to work on the D15 yesterday. One back rim had a bad tube so I decided to drain the fluid and remove it before going any further. I started the tractor at an idle to move it and my noise is gone. Even when running at full throttle nothing. Oil is clear and not showing signs of anti freeze. Do you think it might have been a piece of carbon on top a piston? I guess I should have ran it longer to see if still getting pressure in the radiator or if I just had overfilled it? I have a set of combine tires and rims off a Deere 55 that I am going to put on it untill I get the current rims sandblasted and a repair around the valve. Tom
