Thinking of buying a 8N, at most I would be doing 15 acres. And not all in one area. Soils aren t hardpan. But, two of the old homesteads has some serious overgrown grass mounds(hill). Mostly doing small fields and old logging roads. Weight is an issue, that is why I m going with the 8N. We have some areas that we will need a lighter tractor due to wet areas. Question is, I don t know what attachments(size) that fit best with this tractor. I would like to have the implements go outside the tires a bit of possible. Size of disk, Bush hog, bottom plow, rake and size of back blade. Any help would be appreciated. Thank you
