Bruce from Can.
- Location
- Woodville, Ontario, Canada
In a earlier thread, wolfman was asking about using
a short grade 8 bolt instead of a draw pin, to keep
from having hay dragged by the draw pin from being
a problem. What I do is find a piece of pipe that the
draw pin will fit through, and cut off a piece at
whatever length needed 1-2 inches, and put the
pipe on the draw pin, before I drop the pin into the
baler, or rake or haybine . So long as there is
enough draw pin sticking through the bottom to put
a hairpin through, and no more dragging hay. With
my old NH haybine, when I unhook, I leave the
piece of pipe slid down the jack handle. The baler
pin stays with the baler, and requires a different
length of pipe. Simple solution, and no worries
about the draw bolt being too hard, or soft.
