In the last 4 days I think I had seat plate form off 5 times changing plumbing should have just left it off. Anyway hydraulic are working fine Loader is on tractor. It all comes down to understanding end cap flow. If you look at aux valve there are 3 ports, center port is pressure and top port is return. Can you make a 2 hole end cap into a one hole end cap yes, Plug return hole. So now I have pressure to loader valve and return in old drain plug hole under axle. So far all is good and working.
You are not off the hook yet, some day I will Take the hydraulic unit off my 385/238 and try to fix the hiccup. I will be calling on you again. Thank you
