3 point hoe
714_run
I have a three point backhoe with a frame mount and a pto pump for my four cylinder Ford. The backhoe works fine and is in good shape. The problem is the wiper seals on cylinders are shot. Do they make a split wiper I could put on without taking the cylinder apart? (Wishful thinking?) I hate to take them apart when they don't leak. Thanks!
Wipers arnt going to fix a thing. There is some kind of seals either U cups or Vee packing inside gland that seals on rod and the piston seals need replaced at same time. Good hyd shop can match or reseal your cyls.
