onefarmer
- Location
- 6735 S Lowell Rd, St Johns, Mi 48879
I've been having rear tire issues off and on for years on my JD4430. They seem to be going flat for no reason. I was having the tire store do the fixing but that got expensive. So now doing it myself.
On the tires that were on it original, lasted for years and then started in going flat. After 3-4 repairs I got mad and put new tires on figuring a belt came loose and was rubbing a hole on the tube. That worked for awhile now the new tires are doing it. I check for nails, thorns, and holes in the tire and never find any. I event check the rim and nothing. I put in a new tube and they last for a year and they go flat again.
I even added more air so they wouldn't wrinkle under a hard pull. I don't use this tractor only for heavier field work. It's not like a daily driver.
