banjoman09
I posted a few days ago about fuel pump issues on my Chevy 2000 truck; any chevy technitions here? Not me! If so please email me to help me figure out mu problem- I dont want to post here again. Thanks!
(quoted from post at 09:18:00 11/09/20) Thank you Ok Ill try to start from the beginning; Our 2000 3500 Chevy Pickup just died this summer in the field. So- Fuel pump
does not run- so I replaced the Relay- nothing still. I pulled the relay out and checking the 5 relay pins in the box; pin 86 is
ground and I checked it -it is good. Pin 87 is HOT all time and it is hot. Pin 85 comes on for 2 seconds with the key...and it
does! So I put relay back in and nothing...pump not running. So I took a paper clip and jumped pin 87 to pin 30(the fuel pump
wire) and walla! Tha pump is running! BUT, when I put new relay back in the fuse box- pump does not run? SO now what do I do?
Thanks again.
So if 86 is grounded and 8t is hot with key on and cranking and it runs with a paper clip between 87 and 30 a failed relay is the only possible problem. Double check to make sure all of your inputs are correct. If they are see if you can get an OE number off your original relay and have your parts supplier cross it, as not all relays that look the same are the same. Let us know when you solve it or if you need more help(quoted from post at 09:18:00 11/09/20) Thank you Ok Ill try to start from the beginning; Our 2000 3500 Chevy Pickup just died this summer in the field. So- Fuel pump
Thanks again.
(quoted from post at 11:55:11 11/10/20) We have had alot of relay issues with this truck...any ideas? How can I check amperage draw on this pump? Can I do this through
relay box with truck not running? Thanks
Are you talking about the fuel pump repeatedly failing? Theres no way a failing pump would draw too much too burn up a relay. It will blow the fuse first(quoted from post at 09:55:11 11/10/20) We have had alot of relay issues with this truck...any ideas? How can I check amperage draw on this pump? Can I do this through
(quoted from post at 20:25:41 11/10/20)Are you talking about the fuel pump repeatedly failing? Theres no way a failing pump would draw too much too burn up a relay. It will blow the fuse first(quoted from post at 09:55:11 11/10/20) We have had alot of relay issues with this truck...any ideas? How can I check amperage draw on this pump? Can I do this through
