How to view ago parts book?
Rkh
Is there a worse website for looking up parts? I looked at you tube & that didn't help. I have the mf65 & can someone give me the step by step to find parts on this lousy website? Thanks
There's an option on the home page of Agco parts to sign in as a guest. It's the tabbed box on the lower right hand side of the page. Just for because, I clicked on it, made it to the search page & typed in 333 which is an AC planter. Came up just fine. Typed 65 into the search bar, checked the exact match box, checked the box in the bar on the left hand side for Massey Ferguson & bingo! It came right up. If you would rather, I left a link to the MF 65 page below. Should work.
Mike
Fergie parts....
go to www.agcopartsbooks.com
to the right under guest user click "view books"
type "65"in the search and click the box "exact match"
your 65 tractor is the third book choice down
hope this helps
agco
Thanks JoeM(GA, a big help. Looking for part number for rear weights, but couldn't find.
FYI. The Agco parts books won't make a direct link to a specific catalog for others to use, at least any time I have tried to give someone a link for over a couple years now. One has to go to the homepage and use the View Books in the guest user area, unless you have an account set up by your dealer. It works just like Absent Minded Farmer, JoeM(GA) have posted. Type your model (65, not MF65) in the search box, Check the box beside the right manufacturer's name (Massey Ferguson in this case) and Check the exact match box, these two checked boxes reduce the choices to sort through.
i use to try the agco online parts but had trouble finding parts for my grandpas oliver. so i bought a parts book from jensales. with the trouble with the case new holland web site im going to get more parts books from them.
Please go to the page JoeM(GA) gave you and read it, the weights are also on that page.
There is a small search box at the upper above the index for the 65 parts book. Type weight in the box and search. It will direct you to wheel weights on that same page.
#18 and #25 ?
#18 2 Weight (For 28" Or 38" P.A.V.T. Wheels) (75 Lbs.) (Order 677206)
#25 2 Weight (For 24 Regular Wheels And 11 x 28" Or 14 x 30" P.A.V.T.) (80 Lbs.) (Order 677229)
God help you agco used to be the worst parts book online but now they all are a pos but still not to level the agco books are
