akclark1023
New User
My 9n is propane converted. Not an issue I have a tank and a wet
line and got a crash course when I bought it as to how to fill the tank
and not do anything dumb.
But, my tank is on the grill (100 gal tank) and it was brought over on
the Mayflower. Unfortunately, the tank is leaking when its on or off
from the valve where you turn the gas on or off. It has a weird type
plug in that goes into the valve - much unlike a modern tank which is
a ton easier to fill. This one fills from a separate valve than the
outgoing line and has a hard to reach and twist release down on the
side (not the screw type the new tanks have)
I have the distinct feeling if I bring it in theyre going to tell me they
cant fix that or that its outdated and no longer serviceable.
Im ok with that, Im happy to buy a modern tank. I am, however,
stuck on how to repair this? This outgoing line that goes to the
vaporizer goes into the valve not like a modern tank.
Can I convert this set up to a modern tank? How do I find out what
size regulator it requires? Most of the lines Ive checked out are for
grills and I have the idea that a 30 psi isnt going to be enough to fuel
a tractor.
Not sure where to even start on finding correct parts here. Im
mechanically inclined enough to understand how it works basically.
Other consideration here is sometimes it gets doggy and will stall,
mostly in the higher gears (3rd) and will stall if you put it into road
gears on the aux even in first. This leads me to think its either
flooding or starving but Im not sure which - guess is fuel starved.
But I dont know how to adjust any of this crap and I dont know
anyone who does either.
I prefer to keep it propane converted because it runs clean (spark
plugs and oil are pristine) and cheap.
Thanks in advance.
a tractor.
Thanks in advance.
