4020 LP tractor
wayspill
New User
Tractor dies soon after starting. Wait at least 2 hours and it will do the same thing. noticed the fuel filter/strainer gets hot quick. Never noticed before. Is this normal?
Is it the strainer getting hot or the convertor? Convertor will have 4 or 5 lines connected. Fuel in and out, and Coolant in and out, and might have a air filter compensation
line. Parts of the convertor will be warm when the engine warms up as it uses engine coolant to vaporize the fuel instead of exhaust heat conducted through the manifold on a
gasser.
If it is your strainer getting warm (two fuel lines and a wire) you have a solenoid going bad and that is why it only runs for a short period.
hth
jt
Welcome to YT
I suggest to check volts at coil(item 3) when it's activated & check for good ground connection of coil. New coil is part # AR52766 @ $241.77 from JD
(reply to post at 20:39:18 07/18/21)
Thanks. The solenoid on the strainer was getting hot. I took it off and it was "sticking". I cleaned it and put it back on. It seems to be working for now. The tractor still will not start. Where can I get another solenoid?
(quoted from post at 17:40:51 07/20/21)
(quoted from post at 22:45:43 07/18/21)
Running the tractor on vapour or liquid ? Do you have the JD operators manual ?
Run on vapor most of the time.
Under heavy loads at low air temperatures,in particular if your fuel supplier has slipped some lower cost butane in with the LP .
The tank pressure can drop and not push enough fuel to the carb .
