Geo-TH,In
Look What Happens to a Low-Mile Ford Diesel With Tons of Idle Time and No Maintenance,
Thought I would share article I ran across
ford diesel
ford diesel
(quoted from post at 04:34:39 09/02/21) Look What Happens to a Low-Mile Ford Diesel With Tons of Idle Time and No Maintenance
(quoted from post at 13:44:10 09/02/21) It really makes me wonder who really needs a diesel pickup. I see lawn mowing service people that have a 16 ft car trailer and a Duramax. There are people that trade every 2 years. One guy i know has traded Duramax's every 10,000 miles for the last 3 or 4 trucks and none of what i mentioned pull anything but a skid loader very occasionally. IDK.
(quoted from post at 10:04:28 09/02/21) If you must idle them then it is best to run the RPM up to maintain coolant temps and combustion chamber temps . As a diesel engine will cool way down when idling to the point of incomplete fuel burn and this leads to carbon build up and cylinder wall washing along with oil contamination . In days gone by for us that ran semi's on the road when winter set in and ya needed sleep before you fell across the steering wheel of fell in to the old bunk house you set the hand throttle to find the sweet spot where the engine smoothed out and would not rattle your filling out , this would do two things (1) it made for a good nights sleep and (2) kept the engine temp at of slightly above 180 degrees along with full oil pressure . Old Detroit's would drop oil pressure way down at idle but off idle they would hold around 40 psi. One could always tell when someone did not keep there engine speed up and temps up come morning when they went to pull out as they would blow white smoke for miles burning off excess fuel and oil build up . You could also tell where the cold running detroit spent the night due to the huge puddle of oil and excess fuel was layen
