(quoted from post at 10:32:23 02/19/22) I wouldn't think so, low voltage should make them last longer, less power, less heat! Incandescent light bulbs last much longer if the voltage is low.
(quoted from post at 05:55:23 02/19/22) Ive burned up two in a week only after I started plugging into the barn . Can to low of voltage kill a block heater?
(quoted from post at 09:05:11 02/20/22) Im not sure Jim I think 750 watt with my truck meter I finally
found I did some checking hopefully this spare heater I found
is still good ? So the breaker tripped at the barn this time had
to drive my other truck after I found voltage there I came
home plugged the one with the block heater issue and sure
enough I could hear it working right away . So Im still not sure
why the first heater quit working though Just poor quality i
guess
(quoted from post at 11:12:57 02/20/22) > This is a spare heater I had I think they are 750 watt . The voltage is at the outlet nothing plugged in
Can you dig one of your failed heaters out of the trash and see how many ohms it is? I'd expect it to be open.
You really want to check your voltage under load, since you could have a bad connection someplace that won't show up until you start drawing current. Ideally you want to check the voltage as close to the load as possible. One way would be to insert a <a href=https://www.homedepot.com/p/Leviton-Grounded-Triple-Cube-Outlet-Adapter-White-R54-00692-00W/100356925>cube tap</a> between the outlet and heater cord (or between the extension cord and heater cord), then read the voltage at one of the other outlets on the tap. I think you'll be surprised how much voltage drop you get when the heater is plugged in.
(quoted from post at 09:14:02 02/19/22) Thats what I thought Ive been running the heater no problem for 6 months at the house on the same size cord its a 14 its the same 14 gauge cord Ive been running my 1500 watt tank heater on for 4 years now . now Im plugging the truck into the barn with a different cord and its burned up two heaters in the truck this week . Ive got a 1500 watt stock tank heater running on 250 feet of 12 gauge and the last 50 feet Is 14 gauge heater is on its second year burned the last one up when I let the water in the trough go low a d exposed the heater element to air
