(quoted from post at 15:41:17 04/11/22)
(quoted from post at 16:47:59 04/10/22) I have a 2001 Dodge Dakota that is one of my daily drivers. Last fall it started using antifreeze. Think a water pump. Well I only got an estimate then before parking for winter, it is only a 2 wheel drive while my other Dakota is 4 wheel. Last fall the estimate to repair was $150, now getting out to get repaired, same garage now estimate $350 for what was the $150 last year. What would you think would make in now $200 higher than last fall. Have parts gone up that much.Going to take in tuesday. I am not a mechanick and at 78 even if I was I could no longer do something like that. This is a garage-tire store that have delt with since the mid 90's. Tried getting on O Rileys and Advance to see what their price would be. It is the 6 cylinder model and automatic.
$150 last year was a low ball quote, parts for that truck haven't gone up that much.
A quick search on Rock Auto found a Dayco water pump for $45, Dorman heater bypass tube was $28, you'll need that was the original is glued in and won't come out, while I was there I'd replace the coolant bypass hose between the intake and water pump, and recommend to the customer that we replace the thermostat while it's easy to get to.
Most shops if they get the parts they will mark them up at lease 50% so parts and antifreeze will cost you $150-$175
Local independent shop here get $60 per hour while dealers charge $100 per
The job would cost me $275-$300 quoting those parts to be changed.
Me and the shops I deal with have a firm understanding that if any additional work outside the of the original job quote is needed, they are to contact me before that work is done, even if they have to shove it out of the shop while waiting for me to call back
Any mechanic or shop worth it's salt will have a coolant system tester to pressurize the system and find the leak. A intake, timing cover or thermostat leak is not going to leak out of the water pumps weep hole and run down the fact of the timing cover
If the leak is other than the quoted water pump the owner needs to be contacted with new quotes for the needed repair before any more work is done.
