2355 pto will not disengage
Plant Doc
Open station 2355, pto will not disengage. This tractor has the pto lever on the left side of the dash and it activates a hydraulic control that engages and disengage
the pto. Don't know where to start looking for this problem? Tractor has a lot of hrs on it, but not many pto working hrs. I need advice. Thanks in advance.
Remove sheet metal cowling that covers trans case & look for a hyd test port. Sounds as if valve isn't shutting off hyd pressure to pto clutch or pto clutch plates are warped
