Im pretty handy with gas stuff but I know absolutely nothing about diesels.
We have a deer 2640 that I use 8-10 hours a year for Bushhogging.
Bought it about 10 years ago and it has been a good tractor. I have changed the hydraulic fluid and cleaned filters, found that a mid 80s jeep CJ alternator will fit with a simple pulley swap, and of course oil and air filter changes.
But a couple of days ago when Bushhogging, The tractor started bogging down. I switched to a lower gear and it continued to bog. Throttling up made no difference so I knew something was wrong. I started back towards the shop and it eventually died. It will crank right up and run for about three or four seconds and then die again.
I changed the fuel filter yesterday and the fuel looks good. It looks like I can also crack the return line on top of the pump the bleeding the air out of the pump itself, but from what I found online it sounds like that plastic ring might have given up the ghost and clogged the pump.
To local people I trust have said that it has to be calibrated so its not something I should attempt to do on my own.
So my first question is, is there a way for me to definitely determined that the injector pump is the problem? I would hate to take this thing off and take it somewhere for a rebuild only to find that it was something else causing the problem
Second question is, I understand these are times with the engine. Local diesel mech said that it should be keyed and that the gear stays in the engine so that as long as I dont pull the shaft out of the engine it will stay in time. Can anyone verify that on this particular model?
It also looks like there is a solid metal piece centrifugal clutch(?) that will replace the plastic ring that causes these problems. Does anyone have a link to that?
Ive done timing belt on my Honda cars, and I rebuild ATV engines down to the crank all the time, so Im not afraid of wrenches. I just like to do my research before I tear into something Im not familiar with.
