Probably overthinking this - replacing wheel bolts.
I m looking at online eg Grainger or McMaster and they have just about anything for hex bolts - although I don t know where anything is actually made any more. I see a bunch of different options available - plain steel, black oxide, yellow zinc etc.
I m thinking if I clean up and grease / never-seize some of the original wheel bolts on one side (came off pretty easy and look good) they should be fine as original equipment being put back on. The other side (where I broke one bolt) they were all tough to break loose and all look crappy. So these will be replaced but I m just curious - is the extra spend on zinc plated bolts all around really adding much value, if I grease them up anyway? And recheck / re-torque etc on a regular basis? Does black oxide or zinc option on a bolt really make that much difference in the real world of old tractors?
