unverferth 220 rolling basket harrow bearings
r.w.b.
got them today ,nothing like old bearings. was told new improved replacement bearings. im like ok why?
look like just more expense
big steel block on inboard end of bearing where old bearings were a simple 3 bolt cast flange bearing. now not much ability to compensate used warped machinery. then the next problem. some shafts are wee bit shorter and no way to put the locking ring on.
anybody else encounter this?
im like this it works leave the damm things as they are. improvements dont always work if old 1 is working ok simply wearing out from use.
like my laptop. seems every 3 or 4 days needs an update to improve it. im about to send it to junk pile cause after last update it now takes forever to load and while using it on ant site a blue buffering wheel pops up . progress i guess more shop time for $140 per hour and up.
Nope not had that problem yet. Though I ordered some for it by the number ours is a 1225 just a newer model of your I would guess. I took the bearing number and ordered new bearings from online without the castings then just switch the bearing and put on. Seems to me there was a small ball in the outside race that I had to grind off or jusr drive them in to get bearing to set right in casting. Not sure what the ball was for. Got one out and it did not go through so not for grease.
we ordered bearings.dealer sent complete assembly. when i get back to shop try to get picture
