Pintle Hitch Question
connor9988
Location
Central Iowa
Does anyone make a modern version of this style of pintle hitch?
Looks very handy.
I use a pintle hitch on my Dodge 3500 diesel.
Too much rain to get a photo right now.
Bought at Northern Hydraulics over 20 years ago.
Very stout.
I think he means something that hooks up to a tractor and can be opened and snapped shut from the seat. If not I have this one from TSC. I admit my pintle hitch trailer is a fairly small military trailer. If I had a heavier trailer I would be looking for a different hitch.
I have a couple of these, very handy. work great for their intended purpose as well as a safer method for hooking a tow strap. This one from Reese.
That's a ww2 style hitch found on the Dodge 3/4 ton and 6x6 1 1/2 ton trucks.
Early Power Wagon trucks are very similar.
Check with Midwest military.com, or other military vendors.
Also found on Ebay from time to time.
Tom
If youre looking for one with a rope release like the one pictured, your best bet would be a forklift salvage yard or supplier/repair shop. Every large-scale manufacturing plant I've ever been in used these to speed up deliveries and keep their stock men and forklift drivers moving. I've had a few lifts and cart tugs that had that style hitch as well and its very handy because you dont waste time getting off the machine, toggling the lock up (if it wasnt left up), getting back on the machine to back up and hitch up, get back off again to lock it down, then climb back up and go.
With this type, you just back up, yank on the rope, catch the lunette (ring), release the rope and go!
I dont know if that manual type is till made, but they do make an air-powered hitch that does basically the same thing with a valve or switched solenoid, but they are $400.oo and up...
But without lifting the landing leg, how would you not rip it off? Doesn't look like any means to lift into the ring and then lift trailer.
they would be good for multiple hitch jobs like pulling and dropping trailers, or for off road use like tug work at an airport for the luggage wagons. I don't think I would want to trust one for on road use. Just not a fan of things coming unhitched while traveling. With the conventional models it will not be a problem of coming unhooked. Unless somebody forgets to latch the top and it is either loaded tongue light or bounces off.
I have seen them on over the road trailers. Maybe older ones. I had one on my Kenworth, seemed to work fine, heaviest I think I hauled was my Pettibone about 10 tons plus 2 1/2 tons of trailer.
If you look closely, the one Double07 posted has a safety pin added that can be installed to prevent inadvertent opening. The original post does not have that.
Just my opinion for what it is worth. Looks to me to be very UNhandy. Would have to get out to adjust height of hitch, oops that was 1/2 inch too high, let it down a bit, try again, back in to couple, get out again to lift landing leg, then go. Repeat when unhitching. Of course could have a helper to do all that while the driver stays in the seat.
