Hello Maiku1 welcome to YT! Here is some info on
posting pictures here.
At the end of 2022 the forum host here changed the
requirements to new posters to be able to post photos
from a post count of 5 posts to 1 post. I believe this
change was only made on ..Modern View.. so if you
have less than 5 post you need to post from there. If
you see ..Modern View.. in a gray bar just above the
message text click on that it will take you to Modern
View. In Modern View you will see the Classic View
option in a red outlined box at the top, just adding this
as a way to verify you are in ..Modern View.. Try to post
your picture in Modern. It should go through if you
have at least posted once if everything I understood
about the change is correct. This restriction was a way
to keep internet bad guys from dropping in and posting
bad pictures with hidden viruses. Pictures post
through the ..Choose files.. button or some such name
just below where it says ..Upload Photos/Videos.. down
lower in the ..New post and reply windows, see
attached picture. They cannot be pasted into the text
area as a file.
We are all waiting to see the prize machine given to
you for $100.
