Ferguson T** something
Maitiu
New User
I recently (today) bought a Ferguson tractor. I thought it was a TO35, but when i got it cleaned up a bit found these numbers on the left side of the block: Z120A 600A.
There is not a data plate on the tractor, and I have no other info about it other than it has a gear shift starter switch and a half as 12 volt conversion.
Can anyone help me identify it?
Oh, the color is beige tins, red body.
Thank you for any help!
Your tractor is a TO 20 with the Z120 continental engine .without looking in the manuals just off of memory seems like the serial number for the tractor is also stamped somewhere else besides the plate that's missing
Here is what I look for on the TO models. Both 20 and 30 are four speed, one shift lever, start position is right/forward lever position. The 20 has the oil filter INSIDE the oil pan, the 30 has the filter outside the block under the carb. The 35 has two shift levers, left is R/1/2/3 and right is LO/START/HI.
Thank you! I had questions about what it was because of the start switch in the transmission. I havent been able to locate a replacement except for a TE.
Im going to pressure wash it before i get it in my shop. If there are serial numbers on it, ill find it. There are casting numbers on each of the main parts, i.e., differential, transmission, but i dont have the manual yet to identify them yet. Thanks for the help!
