Fritz Maurer
Have this engine in a forklift, equipped to burn propane. Gasoline injectors disconnected and plugged. Do the wires need to be connected to the injectors for the engine to run? My problem is the grommet for the wires is gone, someone had glued the wires in with RTV. This recently gave way and the original grommet is not turning up anywhere, from Hyster or any auto parts store. Without this gaping hole plugged in some fashion, the engine cannot build enough vacuum to open the propane carburetor valve. If I dont have to have the wires going through there, a flat gasket for the air intake will cover the slot and seal it up.
