Pretty new to working on a garden tractor, this is my first one so bare with me please. I recently got a MW (Gilson model GIL-33045A) and it was running when I got it, but it was wired to use a battery ignition with a automotive coil (some GM part). Well the wire from the coil to the battery melted and messed up the battery. I looked up that if you wanted to replace the original ignition coil you have to pull the engine, is this true? Also could I re wire it for a battery ignition again? If anyone knows any good wiring diagrams of how to re wire it would be great. And I'm not sure what coil I should use either.
Any info helps, like I said I'm pretty novice at this.
