Tractor Talk Discussion Forum
tractor
Mikeinfl
11-20-2006 08:46:58
I'm looking at a tractor to buy, I'm not sure what model it is as there are no identifying labels on it. I think it may be a Massey. Stamped on various places on the transmission,etc. are the letters MHF with different numbers following it. An example is MHF-182-840-M1. Can anyone please give me info about this tractor? Thank you
Bob N.Y.
11-20-2006 16:13:48
 Re: tractor in reply to Mikeinfl, 11-20-2006 08:46:58
Is this a utility type tractor with 3 point hitch? Does it have a drag link on each side that goes to an arm on top of each spindle, or does it have just one drag link on the left?
mikeinfl
11-20-2006 18:05:21
 Re: tractor in reply to Bob N.Y., 11-20-2006 16:13:48
Yes, it has 3pt hitch and pto, I'm not sure what to look for as far as the drag link.
Bob N.Y.
11-21-2006 16:47:39
 Re: tractor in reply to mikeinfl, 11-20-2006 18:05:21
The drag link, or links, is part of the steering system. It connects the steering box to the spindles.
mikeinfl
11-22-2006 10:55:17
 Re: tractor in reply to Bob N.Y., 11-21-2006 16:47:39
OK, I'll have to go where the tractor is and check it out again and get back to you. Thanks a lot for your help.
Aaron Ford
11-20-2006 10:40:01
The casting number you listed does not come up in the 65 parts manual...
How bout a pic? Or the serial number on the dash, or the engine number (by the starter) should start with z134 or something similar...
Cheers
Aaron
mikeinfl
11-20-2006 18:02:20
 Re: tractor in reply to Aaron Ford, 11-20-2006 10:40:01
Thanks for replying. I will have to check for a serial number.
135 Fan
11-20-2006 09:25:11
MHF stands for Massey Harris Ferguson. I'm guessing it could be a 50 or possibly a 65. Need some more info to know for sure. Dave
mikeinfl
11-20-2006 09:36:43
 Re: tractor in reply to 135 Fan, 11-20-2006 09:25:11
Thanks for the reply. About the only things I can tell are that the tractor has a 4 cylinder gasoline engine and is two wheel drive.
