1650 Oliver brake seal
Both brake disks and the actuator. Use a slide hammer puller to remove the seal. See if the bull pinon has any endplay. Do not attempt to remove housing at this point. Questions? J.
Here's a tip for removing the seal- Screw a metal screw into the seal with a small peice of chain on it, and then pull on that with a slide hammer. It'll pop right out.
Donovan from Wisconsin
