5 SPEED FORD 800 TRACTOR PARTS NEEDED
Anonymous-0
LOOKING FOR GOOD USED RIGHT AND LEFT LIFT ARMS FOR MY 1955 MODEL 800 FORD TRACTOR. THE RIGHT ONE NEEDS TO HAVE THE LEVELING CRANK. ALSO NEED A REAL GOOD PAIR OF SIDE BOARDS, RIGHT AND LEFT. THE TRACTOR IS A FIVE SPEED AND I DO NOT NEED THE BRACKETS.
Hey Neal I'm working on a 55 850 ford And may have a set of running boards let me check. I think I still have them. I'll get back to you
THANKS JERRY. I CAN BUY THOSE LIFT ARMS IN THE AFTER MARKET. PRETTY REASONABLE. I JUST FINISHED INSTALLING A 12 VOLT CONVERSION KIT ON MY TRACTOR. I BELIEVE THIS ONE WAS IMPORTED BECAUSE IT HAD METRIC BOLTS. I LEARNED YOU CAN JUST THROW AWAY THE WIRING DIAGRAM. FOR EXAMPLE, THEY HAD THE IGNITION SWITCH WIRED WITH A HOT WIRE GOING TO ONE POLE AND A NEGATIVE WIRE GOING TO THE OTHER POLE. IT COOKED THE SWITCH. THEY HAD A HOT WIRE GOING DIRECTLY TO THE STARTER SOLENOID, IN OTHER WORDS IT STAYED HOT. THEY SHOWED WIRING THE DISTRIBUTOR THE SAME WAY. B0TH OF THESE WIRES HAVE TO GO THRU THE STARTER SWITCH. GOOD LUCK, NEAL
THANKS JERRY. THE AFTER MARKET HAS THOSE LIFT ARMS. PRETTY REASONSBLE. LET ME KNOW ABOUT THE SIDE BOARDS. NEAL
JERRY, IS YOUR 800 CONVERTED TO A 12 VOLT SYSTEM? SINCE I CONVERTED MINE, I HAVE A PERFECTLY GOOD 6 VOLT GENERATOR, WITH MOUNTING HARDWARE. YOU OR SOMEONE YOU MAY KNOW. IS WELCOME TO IT IF THEY JUST PAY THE SHIPPING. SOME PEOPLE, AS YOU KNOW, WANT TO REMAIN ORIGINAL AND MAY WANT THIS PART. IF YOU WANT IT, BUT DO NOT NEED IT, YOU CAN SELL IT. YOU WILL JUST OWE ME A FAVOR. NEAL
