off topic, spark plug for model T Ford
sebas
New User
What size of spark plug use that engine.?
I have one engine at home and i'm thinking in restore it. At first sight i only miss spark plugs and radiator. I also have the gearbox.
I'm in Spain but i hope sparks plug are still available.
Thanks a lot
You can buy any part you want for just about any Model T. Most parts are available new-reproduction, some Ruckstel and Rocky Mountain parts used.
Spark plugs are 1/2" pipe thread. Champion #25, Autolite F-11, etc.
Many Model T owners use adapters to bush down the 1/2" pipe thread holes down to 14 mm and then use more common spark plugs.
I don't have a Model T But i know the Champion 25 works Great, I have some that are "Dressy' with Brass on them and Script Ford and are Takeapart type.. Larry KF4LKU
The Model A if memory serves used the 18mm plugs such as the Autolite 3076 and 3077. I assume the T used the same plugs as the A?
Why purchase bushings to run modern spark plugs
when the original type are redily available
through the restoration market. Champion and
Auto-Lite still make them.
