Anonymous-0
901 Ford Hydro need help? Dealing with a selecto model lifting arms will not lift. It has hydrolic (accs) fittings working! have checked the prime it is pumping! and the fluid level is full. also have removed pump vain checkvalve and spring and cleaned and replaced, but no luck anybody got any thoughts? thanks Ron Odessa,MO
What is the history of the tractor? have you owned it long? has it done this as long as you have had it?
I bought it not running I have recently got running and it would not go into gear got that resolved but cant get lift arms to work Ive owned about a week
Remove round side cover and make sure control valve is not stuck and is moving back and forth with control lever.
