Anonymous-0
Hi Guys,
Need your help...had a new roof put on house, including a new flue stack that goes out through the roof.(only the 36 inch part that goes through roof. Now furnace wont run..inducer motor runs, but wont fire. It is flashing a code indicating a pressure problem...possible reasons "blocked flue" or "high winds"
PRSSURE, DRAFT SAFGUARD, AUX-LIMIT SWITCH(WHEN USED)OR BLOCKED VENT
SWITCH(WHEN USED) DID NOT CLOSE OR REOPENED (DOWNFLOWONLY)
If open longer than five minutes, inducer shuts off for 15 minutes
before retry.
Check for:
* proper vent sizing
* defective inducer motor
* restricted vent
* excessive wind
* low inducer voltage(115VAC)
* defective blower motor or capacitor
* defective pressure switch
* inadequate combusstion air supply
* disconnected or obstructed pressure tubing
Any ideas? Would the new vent pipe cause this?
Thanks in advance!
Mark
before retry.
Check for:
* restricted vent
* excessive wind
Thanks in advance!
Mark
