How To Read V-Belts Numbers
KCTractors
Location
Central Wi
How do you read a v-belt number, for example, I have a belt with the following on it: XDV 58-420, than a space and then this number L542. I need a belt about one inch shorter, than this one. I am thinking that the 420 or the 542, would be a 42" belt. Any information on this would be appreciated! Thanks
Yah, probably is a 42" belt. Measure with a tape on the outside to check. That's the dimension specified. Run a 1/2" wide tape around the tops of the pulleys to be sure a 41" belt is what you need.
Gerald J.
That is a Dayco number and it translates into a 5/8" wide belt that is 42" in effective length.
5/8" wide X 42" effective length:
Replaces OEM Part #:
ALLIS CHALMERS 154273
ALLIS CHALMERS 2025641
DAYCO L542
GATES 6942
GOODYEAR 85420
SEARS SA803
SEARS 10241
SEARS 5A803
SIMPLICITY 154273
SIMPLICITY 164273
SIMPLICITY 2025641
SIMPLICITY 54273
STEINER 81-B039-A
TORO 271-14
TORO 7-1160
TROY BILT 1706383
EDGEWATER 110930
EDGEWATER 114220
ESF 108-542
FOLEY/PLP 108-542
FREDERICK/OREGON 75-224
FREDERICK/OREGON 75-542
LANDSCAPERS GD848
LASER LK542
LASER 95366
PRIME LINE 7-5H420
ROTARY 7587
