Anonymous-0
i bought a new motor/hydraulic pump for my kawasaki mule that dumps the bed.it is 12 volts the motor sets on top the pump it is all one unit about the size of a football.any way i wire it up to the toggle switch .the up position on the toggle switch is supposed to raise the bed and down lowers it.pretty simple operation.the motors wire leads are about a foot long where they connect the wires from the switch this is where i put my volt meter at i have 12 volts going to and threw the motor and back the other wire.so this tells me 12 volts is going to and in threw the motor and back out but the motor does nothing not even a hum.ar first i thought maybe it wasnt getting a good ground so i connected a jumper wire from one of the 2 mounting bolts directly to the negative side of the battery and still nothing.am i doing something wrong or did i just get a bumm motor. thanks RICK
