Anonymous-0
my long lost power and was blowing black smoke. i changed both fuel filters and it helped some but still misses at low rpm and is still low on power.
Cleaned air filter? If it is the oil bath filter the mesh in there can get clogged up and needs to be washed out with cleaner, blown out is possible, and allowed to dry overnight to keep fumes from the cleaner from providing an unregulated supply of fuel. That problem usually comes on gradually, however. Is there crud in the bottom of the fuel tank clogging up the fuel outlet? You can cut the fuel off, take the line loose, then turn fuel back on. If there is a good flow, thats not the problem. If there is a weak flow you can give the cut off a quick blast of air to dislodge the blockage, FIRST taking the filler cap off to relieve pressure from air. Good luck.
KEH
Check the fuel line to the lift pump and the strainer in the pump. If your fuel filters were very dirty, there will be gunk in the lift pump. too.
