Ultradog MN
- Location
- Twin Cities
I changed the head on a tractor today. Old one was cracked - leaking water.
Book says to set the valve lash to 17 I and 21 E.
No problem.
There was a big difference between the height of the heads. Like .080 or so. So I had to crank the screws down a good half or 3/4 turn.
Got the cover back on and the water in and fired it up and boy did it rattle.
Sheesh!
So I grabbed the feeler gage and looked at the numbers closely.
DOH!
The .020 was stuck under the .021
.041 E is a little wide on this model.
Don't you think?
I wouldn't admit to this episode if I didn't suspect you all of having done similar tricks now and then.
Be fun to hear some of them
No problem.
Sheesh!
DOH!
Don't you think?
