I have solved the problem with gas draining into the crankcase. However, I have one problem remaining from the original situation.
I have oil leaking out of the Belt Pulley housing, even when the engine is not running, and thus no Crank Case pressure.
I also HAD oil dripping out the Fly Wheel side, but was able to stop that by tightening some bolts.
I"ve studied JD Parts drawing 48735, but cannot determine what I can do to tighten the Seal at this side of the Shaft.
Any suggestions would be greatly appreciated!
