old
- Location
- Camdenton Missouri
Ok so I think I found where the piece came from which is bad news since they are part of the pinion gear. So is there any way to know the gear ratio of a rear end with out opening it up and counting teeth?? I have 1 half ton rear end from a 1969 but know I would need to use my housing with the ring and pinion from it. I also have 2 3/4 ton rear ends and if one of them would be the same gear ratio as my 1/2 ton one I would just swap the whole rear ends if they will bolt in that is. I figure if I can put the 3/4 one in that would give me better/bigger brakes and also a heavier rear end.
Thank for any help you can give me
