Anyone heard of Kelly Supply (kscdirect)?
Kerwin
This is a follow-up to an earlier question about where to find speedi-sleeves for shaft repair.
I've found a website (kscdirect) for Kelly Supply, which sells both CR and National speedi-sleeves a lot cheaper than seen elsewhere. Anyone ever order from them before?
Thanks for the help.
I have heard of them but I am curious as to how they are to deal with. Which model bobcat do you have? I knew a guy that was trying to put drum brakes on an old bobcat that was belt drive. I come to find out that you could get a factory installed brake on them. But I bet finding stuff like that anymore is about impossible. Where are you located?
Let me know how your speedi sleeve operation turns out. Good luck
Only bought from them once. Ordered speedi-sleeves for my skid loader axles. Good price especially when I needed to buy four. No problem. I received good service from KSCDirect.
K-Mo
It's a Bobcat 371, chain drive with clutches. Sometimes called a mini-Bobcat because you could get it down to 36" wide. I had thought about coming up with some kind of brake for the unit, but that never got off the drawing board. I'm in Wisconsin.
I believe that C/R and National,(now TIMKIN) use
the same part number, also some others use the
same part number. (I may be wrong) and suspect
they all come from the same plant, somplace.
