720 jd radiator core replacement
Anonymous-0
The radiator core is leaking on my JD 720 gas. What is the trick to unbolting the pedestal so you can turn the power steering unit out of the way? Any help would be much appreciated.
just replaced my rad. core on my 720...loosen every other bolt [ped to frame bolts] at the bottom of ped....remember if it is NF you have to have the weight off front to do this ...jack & block up frame...take PS hoses off & stering shaft loose & turn ped..
