1985 Belarus 250 BRAKE problem
HELP...wondering how to adjust the brakes on a 1985 Belarus 250AS?? Also if it is a wet(oil)or dry brake system and if wet...what grade oil and how much to add? There are two adjusting bolts on both sides of rear axle covered by two 1/2 moon covers....could this be where to adjust? All or any help greatly appreciated.
Sullie
Dry band brake.Remove those half moon covers to adjust the brakes.4 bolts hold each cover on.Then you will see the adjustment nut and lock nut on the band.Tighten till you have good pedal.Reinstall covers.
