O.T. Ranger hydraulic clutch
Have never put a preasure guage on one , not sure what you are looking for like lbs per square inor something but I do know this it is not the preasure but the stroke ..that thing just does not move very far. Real short stroke.
JM is right about the short stroke. If you"re replacing the clutch and have the flywheel resurfaced, you need to add a shim on the crank to make up for lost thickness. This is critical because the clutch will engage right off of the floor. Our company has a "98 Ranger with a worn crankshaft thrust bearing that messes us up.
