anyone work in a junkyard or visit one frequently?
Anonymous-0
need the driver side seat belt anchor (where the seat belt clips in at the right of the drivers seat) for a 2006 Kia Sorento EX. Or, anyone know of an online source? Also need one of the seat belt buckles that plugs into the anchor to avoid the annoying beeping while driving around to pastures.
Thanks, Dave
Check your owners manual- some vehicles have a process to go through which can eliminate the alarm. Buckling the belt might also work. Does on my "04 Dodge 3/4.
(quoted from post at 15:43:53 07/12/10) Check your owners manual- some vehicles have a process to go through which can eliminate the alarm. Buckling the belt might also work. Does on my "04 Dodge 3/4.
If I knew how to disable the alarm, I'd be fine. Seat belt works good, just the sensor in the latch is bad.
Dave
CHECK WITH YOUR DEALER!!! It might be covered under warranty.
Federally mandated equipment usually has longer warranties than the basic warranty on the vehicle.
I think the wire that goes to the seat belt lach has to be grounded to the vehicle to make it stop beeping or the two wires have to be connected test it first
