economy tracktor briggs and straton motor
Try jackssmallengine parts at 1-877-737-2787. Hal
PS: I have that engine on an old Toro mower. I rebuilt the engine back in the 1990's.
Here's a web site that covers the old Briggs engines. Hal
PS: Mine has the letters AB after the model number 23.
http://www.asecc.com/briggs/data4.html
The engine is a 23C (F)Flange mount with (B)Ball type main bearings. Finding a new crank will be VERY difficult if not impossible. WHAT IS WRONG WITH THE CRANK YOU HAVE?
Kent
thanks for the info. The owener that I"m fixing the motor for ran it out of oil and seized the conecting rod to the crank. the conecting rod is now in three pieces and the crank is scored
You need to clean up the rod throw as best as you can and see if it's size is near standard. If it is near standard, you may be able to turn the rod throw under size. The crank pin is turned, if it can be turned, .020 inch under size. The 20 under rod is P/N 295362. I would check to see if this rod is still available before you see if the crank will turn.
Kent
