gas vs electric motor hp
I am considering replacing the compressor on my portable gas air compressor. The new ones I see require 3 or 5 horse electric motors. I have the 3hp compressor now ran by a 6.5hp briggs ohv engine. It seemed to pull it easily when the compressor was new. Now the compressor is shot. Will it pull the new one that requires 5hp?
I think the reason it states 2 horsepower requirements is because of different speeds. The common rule of thumb is to double the horsepower when going from electric motor to gas engine. If you can put a small enough sheave on the engine it will probably work OK.
Horsepower is horsepower, but most small engines
have horsepower rated at 3600 RMP. The average
electric motor is rated at 1750 RPM, but you can
get them that run at 1150, 3600, and all over the
place.
The horsepower formula is: Torque x RPM divided
by 63025, equals horsepower. I don't know if the
torque is foot lbs or inch pounds, but i'm sure
someone here will know it
Then the question is: Where can you find the
torqe of your engine/moter, at a specified RPM ?
(quoted from post at 23:34:18 01/11/11) I am considering replacing the compressor on my portable gas air compressor. The new ones I see require 3 or 5 horse electric motors. I have the 3hp compressor now ran by a 6.5hp briggs ohv engine. It seemed to pull it easily when the compressor was new. Now the compressor is shot. Will it pull the new one that requires 5hp?
As previously stated, HP is HP. Where people can't see the difference is torque rise during overload.
A 5HP motor may only be able to produce 120% torque rise when lugged under overload.
A 5HP electric motor can easily for brief periods of time produce 200 to 250% torque rise when lugged.
Depends on the type of load. Constant or varying.
