jd 2940 injection pump
SKYBOW
Superturbodiesel thanks for all the info about the starting problem with my tractor. Looks like I'm either going to have to rebuild or replace the injection pump. Is that as simple as taking it off and putting the new one on? I assume I have to take the old one to a shop to get them to rebuild it. Never seen it done or talked to any one who did it. Thanks in advance again
The injection pump would be the last things I'd suspect with starting problems on a 2940 - as you described them.
White-bottle Power Service won't do much when you dump it into fuel that's already gelled. The red-bottle will - but only if you remove the fuel filter and dump some directly into the filter.
2940 uses the square fuel filter that easily gets plugged with ice chips at the bottom. That's a different problem then gelled fuel.
When you crack an injection line -even when the pump is working correctly, you will only see a few drops of fuel.
Also, injectors do not get "cavitated" if the engine is running - as long as fuel is flowing. If they DID have air, they will bleed themselves out.
I'm not saying CAV pumps never have problems. But, from you describe - I doubt it.
Also note that when the 2940 was brand new - it had many cold starting problems. It was probably the most problematic cold-starting new-generation diesel that Deere ever sold - dating back to 1960, anyway. We sold them new, and had to make many modifications on them. In fact, the 2940 problems led to Deere coming out with new style pistons.
I'm going by these comments you made earlier . . .
"the fuel filter was gelled even though I put new diesel in in Nov and put half a white bottle of power service in at that time. Ran the tractor several times since then with no problems. Thought maybe I had cavitated the injectors so I loosened the two nuts on one injector."
Thanks JD. What do you think would cuse the tractor to slowly loose power and quit-then not start. I put a new filter wilh 911 in it on and pumped it full of fuel wih the lift pump plunger. I then checked that the fule was flowinf. When I turn the motor over I have a spray of fuel before the filter and at the top front of the injector pump. Just drops out of the injector at the top of the motor.
