Should have had this project completed already, but I am running behind as usual. I have a 300 gallon tank that I am going to build a 3 pt. spray rig out of. I would like to use an electric pump vs a pto driven pump so it is easier to regulate my speed while keeping my spray pressure constant. By my calculations, I will need to supply less than 5 gallons per minute. Is an electric pump suitable for this and if so, what type pump would you recommend. I will be spraying coastal hay fields...what type/size spray nozzles do you all recommend.
Thanks for the help,
Timi
Timi
