Governor Sticking
Posted by Bobduck on February 15, 2001 at 07:00:58 from (209.206.230.91):
My governor on my M wants to stick when it's below about 20 degrees.
It works ok under load but won't let the engine idle all the way down.
I've taken it all part and cleaned everything up.
All parts look ok.
Use it to plow snow so have a heat houser/comfort cab on it so it should be warm enough in there to keep the moisture from condensing and freezing.
Any suggestions?
Post A Followup
: Re: Governor Sticking
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
