Re: HELP, Trying to Adjust Wide Front End on Farmall A
Posted by Haas on May 27, 2001 at 08:28:46 from (129.37.117.163):
In Reply to: HELP, Trying to Adjust Wide Front End on Farmall A posted by Little Bubba on May 27, 2001 at 01:09:59:
These things really get rusted in solid. Rust occupies a lot more volume than iron and hence when the rust is in a confined space, it really tightens things up. I think your best bet is to apply heat. Especially on the tie rods. For the axle, heat and also rig up something that will allow you to apply constant pressure to the ends of the axle. Maybe a 3/4 inch pipe clamp as used normally for woodworking. Or use some pipe and angle iron to make a jig you can use with a hyraulic jack to put pressure on the ends of the axle. Also, using a big pipe wrench to try to turn it may help too. However, that may put some marks on the axle you don't want. It's not an easy job some other folks here on the forum have gone through the same thing. It takes patience and perserverance.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
