Re: Re: HELP, Trying to Adjust Wide Front End on Farmall A
Posted by George 2 on May 27, 2001 at 15:05:59 from (216.46.140.186):
In Reply to: Re: HELP, Trying to Adjust Wide Front End on Farmall A posted by george Willer on May 27, 2001 at 05:48:10:
I had the same problem with a Farmall 504 wide front. It was out in the widest position and I wanted to move it in. I took the clamps off, put a smaller bolt (1/2 inch diameter) in the pin hole, dosed it with WD40 and then ran it up and down a washboard gravel road in high gear. After about 15 to 20 miles of gravel road, I tried to push the front of the tire against a tree. At that point I noticed the first movement. I then straddeled the tractor around the tree and pushed against the back of the tire. More road, more pushing, and more WD 40 and finally it was free enough to move. This procedure was then repeated for the other side. It took over a week, off and on to get both sides freed up. I do not recommend heat, and I replaced the tie rods on one side because they were not only stuck but also bent.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
