Re: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Posted by Red Dave - Bob M. what do you think? on May 27, 2001 at 18:04:07 from (64.41.22.12):
In Reply to: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness posted by Gene on May 27, 2001 at 17:04:35:
Gene, I'm assuming that you have a 12 Volt negative ground system. Those readings look about like I would expect. With the switch off the jumper will not have an effect because there is no current flowing. With the switch on, without the jumper, the resistor is dropping 4.88 volts. With the jumper on the drop is about 4 volts less. To put it another way, you get about 4 more volts across the coil with the jumper on. About 8 volts across the coil with no jumper and about 12 with it. That means that you have 50% more volts on the coil primary and that relates directly to a proportional increase in secondary (high voltage side) volts. It also appears that the points were closed when you took your readings. Yes, those readings make sense to me. Red Dave
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
