Re: Re: Re: Hot Engine
Posted by john d on August 12, 2001 at 20:12:44 from (152.163.197.178):
In Reply to: Re: Re: Hot Engine posted by Wayne Fusselman on August 12, 2001 at 18:40:27:
At least two factors may be in play here. As the engine gets hotter, the oil gets thinner, and the pressure will drop. Secondly, as the engine gets hotter, all the clearances in the engine tend to open up a little, and the oil pressure will drop. I'd suggest your first step should be to make certain your cooling system is working properly, by checking the tension on the fan belt and looking for crud in the radiator fins that will block air flow. The temperature gauge may say things are okay, but as these old tractors get older, those gauges often become less accurate. If the engine temperature is truly okay, you may be headed for some problems. You mentioned smoke... black smoke is generally un-burned fuel; smoke with a little bluish tint is oil. Even though it's running well, if the engine is putting out oil smoke, that's a clue that the rings are nearing the end of their life, and you can bet the rest of the engine is getting a little loose also. It won't make a new engine out of a tired one, but sometimes changing the oil to a heavier SAE # will help. The recommended oil is SAE 30. SAE 40 will be a little heavier when warm, and will likely result in a little more oil pressure. Now I know there are some guys on this board that will have some sort of spasm at this suggestion, but here goes..... In spite of the fact that multi-grade oil (10W-30 for example) is not usually a good idea in these engines except when starting them in extremely cold weather, you could do worse than changing your oil to 20W-50. If the engine's losing oil pressure when hot, that should help, and it won't hurt a thing.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
