Re: How Do I take an IH-300 out of Storage
Posted by Bob M on August 23, 2001 at 12:45:47 from (165.170.128.65):
In Reply to: How Do I take an IH-300 out of Storage posted by Ken Tajchman on August 23, 2001 at 11:45:08:
I encountered pretty much the same situation with a Super H that sat unused the the back of an aunt's barn for 10 or so years. My son and I successfully got it going by doing the following: 1 - Drain the oil, install a new filter and refill the crankcase with fresh oil. If the tractor has live hydraulics check and refill the hyd reservoir. 2 - Remove the spark plug and squirt a couple ounces of motor oil into each cylinder - leave the plugs out for now. 3 - Remove the valve rocker box. Dump a quart of fresh oil over the rocker assemblies and leave the cover off. 4 - Using a hand crank, turn the motor over a few revolutions. Observe each pair of valves looking for any that are not moving (stuck open). If any are stuck try to free them up with some light tapping or turning with a vicegrips. 5 - Once your are satisfied the top end is OK, replace the rocker box, stick a new battery on and try cranking the motor (spark plugs still out). Crank until the oil gage registers anything above 0. This is to precharge the filter and internal oil passages. 6 - Remove the sediment bowl under the tank and clean it out. If there is any gas left in the tank, drain it out and discard it - it'll be NG. Reassemble the sediment bowl - good idea to use a new gasket when you do. 7 - Dump a few gallons of fresh gas into the tank and open the fuel shutoff. If you are lucky the carb won't begin dripping gas. If it does, shut off the gas and plan on doing a carb rebuild because the float is stuck. 8 - If the radiator is empty, fill it to about 1" of the top with plain water. 9 - Replace the plugs (recommend installing new ones....). 10 - Cross you fingers, turn on the ignition and crank her up. If you are lucky you'll be rewarded with a large cloud of oily blue smoke and a running tractor. Once you get it going, check for oil pressure, oil and water leaks. Good luck!! PS - The 300 was never offered with a CD player. However "open air conditioning" was standard equipment!
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
